4-channel amp produce distortion when bridged???
  • 6
PrinceCharming
PrinceCharming
Does a 4-channel amp produce have any noticeable distortion or overheating problems when bridged into two channels at 4ohms? I've been looking at the PPI P900.4 or the to drive my JBL C608GTI MKII components. Yes I know that's a little overpowered but from what I've read these JBL's can take some serious wattage. I just need to know if I should get this or find a good 2-channel, as far as SQ, distortion, and overheating go that is.
A good 4 channel amp shouldn't produce a lot of distortion when bridged. Generally you will get more distortion when you bridge 2 channels, but it shouldn't be noticable. If your not pushing it, the amp shouldn't overheat. It will probably produce more heat when its bridged then it normally would.
active means you power each speaker (each tweeter and each woofer) from dedicated amp channels. so you need 4 amp channels for a 2-way component set. you don't use the passive crossovers with active (by definition it means using active (electronic) crossovers to filter signals to each speaker).
passive means you use external passive (non-powered) crossovers (using resistors, capacitors, and inductors) to filter the signals. these rob power and produce heat and phase shifts.
however, i've done much testing with several component sets active (non-bridged) vs. passive (bridged). and more power (bridged and passive) usually won out - especially at higher listening volumes. doubling voltage does wonders for headroom and dynamic range.
distortion adds (since you have two channels, each with their own THD, driving the speaker), but any distortion common to the amp design can be cancelled at the speaker (if the noise out of phase).
since bridging doubles voltage which quadruples power - you actually operate at a LOWER THD level when compared to the same output power with non-bridged. this is because bridging takes much less voltage to reach the same power level. (and less voltage = less amplification = less THD)
i think you may have lost the guy with that last sentence
Awesome responce.
eh, that last sentence just explains the math...
i've worked out the equations by hand... math checks. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
For high end components it is a good idea to go active, isn't it? As you said, at higher volume levels passive is generally better, is that universal?
ok second to last sentence, not the one in parentheses lol
i got you but some guys will skim that and mis interpret your explanation
my comparison of active vs. passive is using the same amp for both. so take a 50Wx4 amp and run it active or bridge that amp to 200Wx2 and use the passive crossovers. the latter gives you much more power and dynamic range.
but passive crossovers are annoying and cause many issues. eliminating them lets the amp drive the speaker directly - giving you full control over it.
i run active and will always run active. you either live with less power (less volume output) or you buy larger amps.
I MUST HAVE CONTROL!!! lol THANKS!
That a great response thanks and it's much simpler than what I tried to read. How bad really does a crossover use up power and create extra heat?
the heat is just wasted power and lower amp efficiency since the amp produces signals that the crossovers attempts to block with impedance. amplifiers don't like seeing large swings in impedance - and those swings will affect what you hear.
the impedance plot of a comp set is not flat...
i didnt think id ever read you typing that, though to a point i agree, but again a good install can overcome alot of the output problems. which the methods ive used in the past have been learned by studying your installs, so like i said shocker to hear that from you. cant wait to try that fiberglass trick in my new car!! just waiting for the sundown comps to arrive then maybe the mille when the next job starts up
10
505
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
687
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
942
PrinceCharming
PrinceCharming
PrinceCharming
New Albany, MS
akheathen
    May 12, 2024
Brendon Jenness
    May 11, 2024
