4 channel (400w), 2 channel (600w)...What amp kit?
customcamaro
Ok I have a jbl 600.1 and a US Acoustics 4085. I will be powering 2 12" infinity perfects off the 600 and 2 CDT CL-61's as well as 2 unknowns have to figure out what I want). I went to a shop to get a quote for install of everything and price was good except all neccessary wiring and such came out to over $180. Can someone tell me exactly what kits i would need from Knukonceptz.com or another reasonable priced place so I can try to cut some of the cost. Thanks for the help.
http://sonicelectronix.com/item_3934.html kinda pricey
http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SWK4D&Product_Count=1
But If I were you... http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SWK0&Product_Count=1 then just get some 4awg and a distro block to split the 1/0 to two 4awg outputs and run those to the amps.
I've seen your car around town. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif That Asbury is huge.
The only thing about that kit is you have to use 8awg for connections to the amps...so I'm not sure how great it'd work with the BP. I know the US would be fine cuz it only pulls like 30A but the JBL could pull over 50 on peaks.
In all honesty, I'd get http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SWK4&Product_Count=1 then http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SDB034&Product_Count=1 and lastly get some http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SCPRO4R&Product_Count=1 to cover the extra wire for the other amp. You still will need some RCA's but those are cheap.
That way you are running 4awg the entire way. So the amp kit then run the kits power wire to the distro block and split it off to the two amps. Best way would be the 1/0 Stinger kit, distro block, and extra 4awg but that costs more.
If you need help, hit me up on AIM and since you are local I could possibly help you with it if you needed.
customcamaro
customcamaro
Tulsa, Ok
negativezeroz
