4 15s VS 2 15s
yea box needs to be re designed. you should def be doing more then a 146 or 147 with 4 15s
This depends on power... Jon Armault (HiSpls) has a very nice setup with 4 Sundown 15 hybrids in a jeep tuned to like 40+hz and only smack a 149 but he also is only running like 5k to them.
If you have room for 4 15's why replace with 2 15's and not 2 18's. Nowall astros with 2 18's can break a 160, so box is definitely your problem.
this is true. im just saying with a better box design they should be able to be higher numbers. ive never seen the sundown hybrids so im not to familiar with the size and motor power. with my 1 hdc3 18 i was doing 147+ and power wise i had a planet audio bb2400.1, rated 2400@1ohm(actually clamps about 1800 @ 1ohm )...after voltage drop and imp rise it was probly only seeing about 1000rms if even that much. i had a street box, no wall.
I think proper airspace should not be undermined. Obviously, your not gonna beat 4 15"s with 2 in terms of shear output, but the 2 in a huge proper sized box may sound better and probably get lower.
eh its not the greatest cuz last set up i had hit 146.7 with 4 alpine type r 15s tuned to 29hz on a saz 2500...but like i said the gain was suppa low cuz i thought i had burned um out(due to smell) lol
2 12s can do 147s on 5,000. 4 15s should definitely be at 149-151
i did 146.7 on 4 15s with ONE sundown saz 2500/ my current set up im running bc 5500 but i think its partially subs fault lol box builder is pretty well known for his work & has alot of good boxes, he hit higher score with 4 10s in his 4th in a camry
like i said SOUND better these honestly sound good but i didnt exactly go for numbers had it running at 2 ohms for all 4 decided to drop it to .5 at comp just to see what scare i was at then but i demod a bit at .5 it got super stinky so i set gain really low then was rushed to test at hit that im more then positive i can retest an get a better score but that was my rushed quarter gain score, no excuses just explanation ..
my box..
looks loud as hell. whats the problem?
it is loud as hell but the life of a bass head never ends
lol
im gonna just go head an tune to like 27-29 hz an do atleast 1000 rms subs
---------- Post added at 01:28 PM ---------- Previous post was at 01:27 PM ----------
cool //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ima just stick with 15s just replace the ones i got with beefier ones
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
974
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
853
You may need to go to some shows and sound offs/meetings
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
Joe562MMA
Joe562MMA
Los Angeles , CA
Joe562MMA
