4 12"s 4ohms drop to 2ohms
weedy
I have 4 kicker comp 12" subs and a 1000w SSL evolution monoblock amp thats 2ohm stable. i want to spread 1000w throughout the build, puting 250 watts per sub. now i want all the subs to run off the monoblock at 2 ohms, how would i go apon wiring that.?
If the subs are DVC you might can do this
That is 1 ohm.
If your meter is showing you 2 ohm then try this.
Leave it on the correct setting to test the ohm. Then touch the leads together and see what the internal resistance of the meter and leads is. Then subtract that from the number it displays when you check your wiring.
weedy
weedy
Naples, FL
juanmgarza26
