4 10''s box plans needed. kthnx
Well, there are a few diffrent styles of "CRX" boxes. I believe you want a slot port subs up port back. What are the dimentions you have to work with? What kind of subs are they do you have pics of the car it is goin into?
With those dimensions, that only gives you about 5cuft before port/sub/bracing displacement. What subs are going in it? Most 10's are going to be happy in 1.0-1.25cuft per. So that's going to be tight.
CRX style like this.. Subs Up Port Back
36w-14t-22d
crx style port, 4 subs on top. tuned around 33hz. If you can help me out that would be sweet, going to be buying wood tonight so if someone can load something up for me that would be great.
let me know how it sounds
i hope credence has 2 more tens i want to go 6 10's sealed in my accord
Again, this is something quick from the RE box builder
Enter these amounts:
Width - 14
height - 36
top depth - 22
bottom depth - 22
wood - .75
Port width - 1.5
Port lenght - 0
It gives 4.427 ft^3 @33.13
Or you could also go with 1.75 for port width and 8 for length for same tuning
btw...with that small of a box for 4 10s....you'd possibly be better off going sealed.
4 10s...that need at least 1.5 per ported to get any kind of low note out of them.
Thats 6 cubes...which is already bigger then the max dimensions you've got.
IMO go for 2 subs in a perfect enclosure instead of trying to shoehorn 4 in there
2 will be louder IMO
even if you go with 4 cubes after displacements...say each woofer displaces .1...that leaves you .6 usable space to use for a port.
You don't have a big enough box to let the be short to get the tuning you want, so say the port has to be 20'' deep...34.5'' wide, and 3'' tall
thats 1.2 cubes of port displacement, and thats still tuned kind of high for that small of an enclosure.
So if you did your port like that...your enclosure would be around half a cube per sub...and in that small of a ported enclosure you'd have no low end output at all
bad @SS chevy
bad @SS chevy
ohio
bad @SS chevy
