3Sixty.2 mint, and everything to run it.
Joseph7195
Walkin Tall
Rockford Fosgate 3Sixty.2 V.2 Mint
This sale is for my 3Sixty.2 V2 with the upgraded bluetooth chip and all accessories to run it(if you're running it with Pre-out. Included is:
3Sixty.2 unit
bass knob with case (new)
bass knob without case (was mounted in my dash)
extra bass knob face plate
Bag with unused bass knob wire and instructions with mounting options
Extra used bass knob wire (used)
Laptop Bluetooth connector- Trendnet TBW-105uB
Owner's manual with original Return Authorization information on back.
Original refurbishing receipt Rockford Fosgate dated September 29, 2010 (I was able to get the new one back from them before Usaci World Finals in 2010.)
Original receipt from Car-Tunes in Greenville, Ms
Original set-up disc (no scratches) in original sleeve.
5" 2' Red 12 gauge power wire.
8" 8' Black 8 gauge ground wire
20ft shielded subwoofer RCA cable
Two 3.2 ft premium Rockford Fosgate triple shielded noise cancelling patch cables.
This has been verified by me to work. I will take a video of it working and fully functional for the buyer before it is shipped and before any money changes hands (and buyer verifies functionality). If any more information is needed, don't hesitate to ask.
$250.00 shipped firm
No Trades!
Shipping included.
ok in my grand prix there is a tweeter and mid for each channel, any idea how i would go about hooking this up?
If you are running stock wiring and speakers they are just wired to the front channels. This unit would not affect them, unless you are wanting run an amplifier for your mids/highs. If you are going to run an amp on them, then it comes down to your wiring. If this is wired up correctly you will have Front (left/right) and Rear (left/right) for your mids/highs. You can then choose the best way to wire up your speakers to your amps if that is your goal.
Yes sir, it can help running active. There are 5 channels that can be manipulated to allow for select frequencies to pass. FL, FR, RL, RR, and center channel can all be high passed, low passed, or bandpassed, or all passed (full frequency passage). They are also able to be adjusted individually in 5 hz increments to the desired frequency range. Just adjust the amps to full pass, and the 3Sixty will actively send the selected frequencies to the selected amps, and nothing else!
well issue being is i have a monsoon system, stock navi. i want to keep it but the way the stereo is in there is dumb. tweeters are off deck mids are on the stock amp. i need to get these signals together somehow
Oh , I see. Well the only thing I could see would be a problem is the stock amp. Since the 3sixty has low and high input options, all you would have to do is take the signal (outputs going to the speakers or to the amp) from the Oem unit and put them into the high level inputs onto the 3Sixty. Just make sure you get the signal BEFORE it gets to the factory amp. An amped signal going into the 3Sixty could possible damage it. This particular unit can actually produce 6 channels of output from just 2 channels of input. The unit during setup will ask if you want to "Sum" the outputs and you say yes, and it will give you stereo imaging (left and right adjustments) but your fader will cease to function. There are many many options this unit gives. These are just the few I can think off the top of my head
Absolutely, it has 5 channels of time alignment adjustable up to 10ft, in 2 inch increments. The control of the system is pretty straight forward too. Download the software form RockfordFosgate.com (free) after you have selected your operating system, hit download. It's also included on the installation disc, but the online download is much easier to install. you can also use a Palm OS device for control of the unit and still have the same control as a laptop. I really liked the laptop control though. Very easy to use and very straight forward.
Sold to Omegabunny! **** pictures are being traded and amp will be on it's way as soon as I have him a video and address! Thanks for everybody's interest in this! You hear about them a lot, but never really hear about all of their functionality. It's a very awesome piece of equipment if you learn all the in's and out's. I hope everybody gets a chance to own something like this one day!
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
michigan born
    May 14, 2026
michigan born
    May 14, 2026
