3kw amps
Your inbox is full so I couldn't message you.
I have a pop corn sound 4k that will do 3k at 1ohm. Has the same board as an opti4601. I would not recommend running below 1ohm since I don't know how it would like that.(never tried it) It has been real good to me at 1ohm.
Where you located?
I could most likely do $320 shipped if your not too far.
here is a pic of the internals
452
576
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Towncar
Towncar
who knows
sw3ll3r3
Decebal
    Jun 10, 2024
