Sold 32 Batteries...newer thread, even lower prices!
RAM_Designs
SketchUp Master
Got the urge to lower the price again to get these things moving out the door. I've had a lot of people asking about one batt at a time, so hopefully this slightly lower price will make it easier for them to buy. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
NO TRADES
I got ahold of 50 of these, but just don't need all of them. They were used in a backup server for 2 years, and are in really nice condition. They look just like the Batcap 800 and Kinetik 600 batteries, just that they have tabs instead of threaded terminal inserts. 17.2ah of reserve, 15lbs, and roughly 6.5" x 7" x 3"...just like the Kinetik and Batcap. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
1 = $45 shipped
2 = $75 shipped
3 = $115 shipped
4 = $145 shipped
Local guys get however many you want for $25 a piece.
I have 8 of the black top ones and 8 of the solid gray ones.
Ok then.. Might as well ask here. Will an irragi 240 amp (115amp at idle) with a stock battery and big 3 be enough to run about 3000rms at its full potential?
I don't see it being possible. "Idle" is actually 2k rpm's, which of course isn't idle at all...when you're idling at a realistic level like 750-1k rpm's, you'll probably only see maybe 80-100 amps out of that alt. Of course, if you lay off the volume while you're idling I don't think there will be any big issues. But trying to bump without having your foot on the gas a little just isn't going to work out well...
Yeah the next upped model is 200 amps 175 idle. Its 100$ more though or is it worth it. I imagine I would have to end up putting an extra kinetic for either or would the 175idle one be fine?
Definitely use extra batteries...it can never hurt. Just relying on your alt to do everything is a good way to wear it out quickly. Extra batts also keep your voltage steady during long bass notes(if you're already having voltage issues).
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
BP1Fanatic
BP1Fanatic
