300x2@4ohms - High End 2 Channel?
exige
Need at least 300x2 @4ohms. So far the only real nice one that I've found with the power and quality I'm looking for is an Arc SE2300. 330x2, but Zeff designed=$$$$$
Let's just say budget is $800-900, and I don't want to run a 4 channel bridged - just personal preference. Class A or AB is preferable.
Ideas?
i got a arc audio 2500xxk i am willing to sell
here is a little info on it
2 x 270W @ 4ohms
2 x 525W @ 2ohms
1 x 1050W @ 4 ohms bridged
THD:
Freq. Response: 20Hz ∼ 20kHz
S/N Ratio: 105dB
Damping Factor: >2000 (1kHz)
Max. Current Draw: 135A
Fuse: 3 x 30A
Dimensions: 18" x 8" x 3.35" (45.7cm x 20.3cm x 8.5cm)
Exige the amp im talkn bout is this beauty;).
STEG 120.2 . Here's the specs of her also
Output Power at 11 to 14.4V:
2 x 120W @ 4 ohms
2 x 200W @ 2 ohms
1 x 400W @ 4 ohms bridged
Efficiency: >60% (at 11V, 4 or 2 ohms)
Freq. Response: 20Hz ∼ 60kHz (-3dB)
THD:
IM Distortion:
S/N Ratio: >95dBA
Damping Factor: >500
Max. Current: 38A
Fuse: 40A
Dimensions: 11.4" x 8.2" x 2.1" (28.9cm x 20.7cm x 5.2cm)
Weight: 5.8 lb. (2.65 kg.)
2 x 120W @ 4 ohms
2 x 200W @ 2 ohms
THD:
IM Distortion:
S/N Ratio: >95dBA
Max. Current: 38A
Fuse: 40A
exige if you want a 310x2 @ 4ohms in the steg thats easy t do hit me on the email and i can send you the info mate
xmplar@iinet.net.au
i can send it via audiobahnuser or straight to you it will be a lot cheapewr than trying to buy one there also these are top of the rqange Steg amps they arent the top of the range steg but i can do that also but the shipping will be alot m,ore as the amps are heapz hevier
exige
exige
USA
Pooods
