n2audio
OPTIDRIVEN
Not exactly convincing examples.That's why I've never been concerned with installing another fuse at my distro block for my 4g to amp from 0g because it's length is under 2 feet and it could easily handle the amperage the 0g can provide from ~15 feet.
You'll see this concept in every day use. It's why your speaker VCs can have such a small wire. It's why your fuse holder can pass 300amps on a very thin piece of solid metal. Length has everything to do with how much a conductor can handle.
Speaker VC's higher voltage - less current.
Fuses - the issue there is melting copper, which happens at nearly 2000 degrees.
With wire we're concerned about the insulation which melts as low as 175 if it's PVC.
