3 xxx 18's sealed or 2 ported
I actually have 4 xxx 18's.
The car is a lincoln LS. The trunck space in 14.5 cubes
I was thinking 3 sealed.... 4 cu ft each. each off a orion 2500d
I was thinkig if it would be possible to fit the forth then i would do it.
Or
2 ported...7.2 cubes uned 28
again the car is a Lincoln lS
none of your options will fit. 7.2 cubes is internal volume so when you add port displacement, especially tuned to 28 hz. and about 100 sq. in. of port you have an external dimesnion of 10 cubes per sub. what kind of power do you have?
I have orion 2500D for each sub.
I really need to fit these in there.
Should i do 4 sealed?
i was thinking of taking out the back dash and having the whole trunk as a shared enclosure sealed. So the subs would be facing up into the roof of the car on the inside. and the whole trunk is the enclosure
lol GL why would you pick 4 18" super subs to try to put in a trunk?
well to properly port them, you need 20 cubes of space in your trunk. 4 sealed would be 16 cubes net, plus the driver displacement, and wood and you are looking at close to 20 cubes again.
Iceteebone where in michigan are you man. Thats where I'm at. Lansing. drop by man
Ey, What options do i have.
Oh yeah. i got the XXX component sets. Should i get another one also.
I lost here with all this XXX rated stuff
i'm near houghton lake about 2 hors straight north of lansing
I cant sell them. I need to SLAM with these. Some one make this work. Il take out cutomize the back seat..LOL
I'll get rid of one or two if I really cant figure out. But I was robbed 350 last time i made a deal on here. So anything will be off the site by phone or local pick up.
BoominBeast
Banned
BoominBeast
MI
BoominBeast
michigan born
    May 14, 2026
michigan born
    May 14, 2026
