3 tens in silverado
I just bought a 2007 extended cab Silverado... I want to know if I put two tens under backseat and one under front dash will it be out of phase? The boxes will be exactly the same shape and size.. I would just go with two decent tens but don't have the air space so I have to get smaller than what I want so I'm trying to compensate with cone area I want to run 1500 rms. 500 watt tens.. I plan on doing 3 2ohm svc to 1.3 ohm..
do 3 8's under the seat..
I have an 08.
You have the late model 07? If so you don't have much room.
Dd makes a 6.5 sub that you can get with a factory box made for the 6.5 and it does pretty good. (No one will feel the bass at a distance tho) I have two of these.
Could do a custom center console and put a sub or two in.
I'm going to pull back seat out of mine and go bigger. But I really don't need rear seat as its my work truck.
If you want to keep a factory look maybe check into 8's or 6.5 subs.
I've heard a quad cab z71 with one of the made in USA dd 8's and it sounded great on music.
2 or 3 of these maybe. HDS2.108 8" 600W RMS 1200W Max Subwoofer.
I love soundqubed / audioque especially for the price. Those soundqubed subs get real loud and sound good at same time. Plus they can easily take 750w RMS without breaking a sweat. I have owned re sx subs , dd 9915 subs and audioque personally and will be getting 1 hds3 to go in my g8 GT soon. I just want a little bump nothing crazy this time.
I may go three 8s but I still want to know if I had onein the front and two on the back would it make a difference?? ...I've been wondering that for quite some time.
And how exactly would I get 3 8s under the seat with the hump there and all?
And I'm looking for subs that do well in sealed.. I was thinking some re sexs on a crescendo or aq
If you have the hump either stick with 2 8's or 2 10's if you want simplicity. Or with 3 8's have the first 2 on each side edge of passenger and left hand side facing forward then you could extend the box out just enough over the hump to make a console so to speak and face that 3rd 8" sub upward. Just a thought //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pic for ideas.
I'm not really looking for simplicity... You ever just wanted to do something? I like doing this stuff. I don't want to just do everything a certain way bc it's easier. I really just need to know if subs in separate partsof a vehicle is a bad idea, specifically in my truck.. It's all in the same cab so... Same box shape and size. I do like the 4 8 idea but in trying to lay out all my options.. It's no disrespect to none of y'all I appreciate the ideas.. I may just have to try it.. Trying to learn from someone else's experience of possible
jdeaton011989
Mississippi
jdeaton011989
vegang
vegang
