3 RD Heavyweight 15s dual 1ohm
daddy_j
PLEASE ONLY POST IF YOUR WANTING TO BUY.
3 RD Heavyweight 15s dual 1ohm. The only resaon I am selling is because I need dual .5ohms. Only trade will be for either 3 RD Heavyweights dual .5ohms, or 3 Atomic APX 15s dual .5ohms or dual .35ohms.
3000-4000 watts RMS
25mm tall top plate
25mm tall t-yoke
Paper cone highly damped with Kevlar fibers
Tri layer wide roll surround foam
Dual stacked 1” tall by 9.25” in diameter magnets
Tall titanium former
3” extreme temp 8 layer voice coil
Resign impregnated poly cotton spiders
Cast basket
Spiders bolted down to cast basket
Triple joint re enforced
15″
FS: 44.7 HZ
RE: 3.6 OHM
QMS: 9.6
QES: 0.412
QTS: 0.395
RMS: 11.05
CMS: 0.0334 MM/N
MMS: 378.26 G
BL: 32.14 TM
SPL@1W: 91.83 DB
VAS: 37.83 L
XMAX: 15 MM
XCOIL: 55 MM
Oh coarse one got the screw hole threw the surround, but black silicone took care of that. Doesn't affect the performance at all. Still stiff and still working 100%. One of them, the push terminal broke free from the other one, and I used epoxy to put it back. It does not affect the performance at all. I still manage a 158dbs with one pf600 amp.
$425 shipped for the perfect one, $400 for the one with the silicone and $400 for the one with the epoxy. I only want to sell all three, so if you want one, then we will have to wait for the other 2 to sell and vice versa, or $1200 for all 3 shipped. If your local and come pick them up, I'll throw in a mojo motor, it is from the 2009-2010 Mojo15Q1 sub (all it needs is a bolt on recone).
included in price.
I was referring to your "decent sub" remark. and "all in all good subs not great". These are better than any other sub on the market, especially if you throw in the price factor. Only sub that can compare to them are the atomic apx sub, only because they are the same same sub.
lol id any day take a incriminator audio warden any day over a RD so yeah in my eyes sure they are just a good sub i dont find them great //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thats funny because these subs hold more world titles currently (in non mod classes) than any other brand. Steve had a problem with a component he decided to use on his amps. Then he decided to burn people. These subs vs DD9515 dual 1s were .4ohms louder than the DDs. Same box same amps, and same batts. Against memphis mojo 15s, these were 1 db louder.
I never knew a sub could be louder in its ohms? i think you meant Dbs..
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
968
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
846
You may need to go to some shows and sound offs/meetings
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
daddy_j
daddy_j
san antonio, tx
daddy_j
