3 RD Heavyweight 15s dual 1ohm
daddy_j
PLEASE ONLY POST IF YOUR WANTING TO BUY.
3 RD Heavyweight 15s dual 1ohm. The only resaon I am selling is because I need dual .5ohms. Only trade will be for either 3 RD Heavyweights dual .5ohms, or 3 Atomic APX 15s dual .5ohms or dual .35ohms.
3000-4000 watts RMS
25mm tall top plate
25mm tall t-yoke
Paper cone highly damped with Kevlar fibers
Tri layer wide roll surround foam
Dual stacked 1” tall by 9.25” in diameter magnets
Tall titanium former
3” extreme temp 8 layer voice coil
Resign impregnated poly cotton spiders
Cast basket
Spiders bolted down to cast basket
Triple joint re enforced
15″
FS: 44.7 HZ
RE: 3.6 OHM
QMS: 9.6
QES: 0.412
QTS: 0.395
RMS: 11.05
CMS: 0.0334 MM/N
MMS: 378.26 G
BL: 32.14 TM
SPL@1W: 91.83 DB
VAS: 37.83 L
XMAX: 15 MM
XCOIL: 55 MM
Oh coarse one got the screw hole threw the surround, but black silicone took care of that. Doesn't affect the performance at all. Still stiff and still working 100%. One of them, the push terminal broke free from the other one, and I used epoxy to put it back. It does not affect the performance at all. I still manage a 158dbs with one pf600 amp.
$425 shipped for the perfect one, $400 for the one with the silicone and $400 for the one with the epoxy. I only want to sell all three, so if you want one, then we will have to wait for the other 2 to sell and vice versa, or $1200 for all 3 shipped. If your local and come pick them up, I'll throw in a mojo motor, it is from the 2009-2010 Mojo15Q1 sub (all it needs is a bolt on recone).
included in price.
I can't figure out why no one wants one of the baddest subs on the planet?
steve miller would be a good reason, his named is tagged with those and always will be.. regardless of what/who owns RD now.
Nice subs overall... but that's the reason why. What spider config do these have? 1 soft 2 other?
steve is not the one selling these. Its not like you get a warranty with subs, especially spl subs. If you ever want these reconed for any reason, you can send them to psi and they will do it with any impedance for only $120 plus shipping. I am giving a 100% guarantee that these will not be DOA, and will be in 100% working order.
I think what he was getting at bud was Steve Miller made these and there where alot of screw ups on steve side but all in all good subs not great but good GLWS bump for a decent sub
thats funny because these subs hold more world titles currently (in non mod classes) than any other brand. Steve had a problem with a component he decided to use on his amps. Then he decided to burn people. These subs vs DD9515 dual 1s were .4ohms louder than the DDs. Same box same amps, and same batts. Against memphis mojo 15s, these were 1 db louder.
lol man i was even trying to be rude just said what i felt personally as u can see man is i run RD as well the RD elites v.2 really goood sub but i just like a different brand
daddy_j
daddy_j
san antonio, tx
daddy_j
