3 RCA outputs work fine just one sounds lower than the rest?
  • 1
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
910
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
726
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
706
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
611
mAdBuMpZ
mAdBuMpZ
Los Angeles , Ca
mAdBuMpZ
audiobaun
    May 19, 2024
    May 19, 2024
