3 JL audio 12s in my bagged oldschool benz
Your subs wont be loud sealed closed off from the trunk(if you do it right). You will lose a considerable amount of output. If you closed off the trunk and ported into the cabin it would be loud as balls.
haha i had a 92 mercedes 300E as my first car. put a 15" L5 in it and actually ended up taking a sawzaw to the back. definitely not the best idea but it was definitely loud as hell after i did. you just gotta watch out cause the gas tanks are located right behind the rear seats. at least in mine it was. but i do not reccomend doing that. i was 16 and stupid when i did. plus mine was falling apart and i wasnt too worried about it
What about this.. my daily driver has dubs on it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif .. 20 inch asanti.. ill be redoing the box soon,maybe add another idmax.
Two 12 inch idmax running at 1 ohm with a sundown 1200d
Here's a pic next to the benz. The benz is airred up at ride height and u can see has no camber issues when airred up..
surprise those front tires last more then a week
I don't drive the car like that. That's just how it looks when the car is aired out.. when I drive it I raise it 3 to 4 inches and the camber is fine at ride hieght. I have about 2 thousand miles on those tires and there is no noticeable wear.
bobbybdemented
bobbybdemented
houston
whitedragon551
