3 JL audio 12s in my bagged oldschool benz
bobbybdemented
This is just a simple build I'm doing on my 81 mercedes 240d. I'm also redoing my air management system. The air compressor and tank will be hidden under the false floor. The subs are JL audio 12w3v3-4. Amps are planet audio rxd1350 and rx 300x4. Mids and highs a diamond audio.sorry for the crappy pics I lost my digital camera.
Here is a pic of the car
Wiring the subs
Subs mounted
Building the false floor and starting to close off the trunk. Everything will be covered in suede when done.
Door pods I made awhile back and a pic of the interior
I will probaly redo the door pods and do some fiberglassing on the rear deck.
Your subs wont be loud sealed closed off from the trunk(if you do it right). You will lose a considerable amount of output. If you closed off the trunk and ported into the cabin it would be loud as balls.
nice and creative...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Do you run your car on veggie oil //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
The trunk won't be completely sealed from the cabin.. there is a hole in the back deck where the firstaid kit was.. if u look at the pick there is a 3 inch gap from the box to the top of the trunk.. and I do run it on biodiesel all the time..
Well then you arent "closing" off the trunk. I thought you were in progress and just hadnt filled the gap in yet. Im not hatin, i like the system, but you need some wheels mane. Some dinner plates or blades should set that off, and if you dont know what those are, you should be ashamed texas boy!
bobbybdemented
bobbybdemented
houston
whitedragon551
