3 Alpine type-r 12"
what kind of amp do i need for 3 alpine type-r 12" subs?
Item Specs:
- IMPEDENCE: 4OHMS
- 1500W PEAK POWER
- 500W RMS
- FREQ. RESP. 32-1KHZ
- KEVLAR PULP CONE
- NOMEX SPIDERS
- TYPE R SUB..
- ALPINE AT IT'S BEST!!
- NEWEST 2006 STYLE
times 3!!!!!!!!
please link me to a good deal if you can
thanks
honestly u would be better off with a 2500d, u can use the 1200.1, but if u wanna be loud u won't be achieving it with 300-400 watts to it...
better off running just 2 and feeding 2 600 watts...
x2
that will only be enough wattage for 1 or 2 subs
go with 2 12" over the 3 12's and use that space to make an actual bigger and better box for them. that way, you can run it at 1-ohm stable (with the DVC 4-ohm). hifonics brutus makes great amps that can be run at 1ohm stable and very affordable. the bx1505 (1500rms) is around $240 at http://www.onlinecarstereo.com . its more than enough for most folks (me).
quality > quanity. if you're on a budget, its a wise choice.
Did you already buy these subs or are you just daydreaming about having 3 12" Type-R subs in your car? Almost guranteed you can have it louder and sound better if you only have two subs and spend the rest on a decent box and dynamat for your trunk.
well i wanted 3 type -r's because i found selling them brand new 06 models for $85 so i could afford 3 i dont no tho if you really think they will sound better with only 2 then i will only get 2 but should i use the jbl jp 1200.1 for the 2? or wht would be the best amp for the cheapest price for 2 12's for under $230
what kind of car do you have, and more specifically how many cubic feet, for 3 you would need to measure out about 9-10 ft^3 Gross. Unless you have a huge car i doubt you have even close to that. 2 is the perfect match for a JBL 1200.1.
HatE-KrymE_5150
Ca
HatE-KrymE_5150
vegang
vegang
