3 10s for a hatchback, Alpine type R or Rockford Punch P3
D0ZER
MN
I recently got a new car ('02 Audi TT) and am trying to figure out what to put in it. I currently have a Planet Audio AC2400.4 for a pair of Rockford Fosgate t2-652s and plan to add a second pair of comparable speakers at one point. On account of the of the goofy layout (25"x37x10" if you round a lot) of the trunk I think 3 10s would work best for me. So assuming I get a sealed box with about .8 ft^3 of space per compartment should I go with:
Alpine SWR-10D2 or the Rockford Fosgate P3D2--10 wired in parallel to 1.333ohms
I plan on powering it with my Hifonics HFi1500D which I assume is overrated but plan to replace it at a later time.
I mostly listen to electronica and have no real affinity to any brands
In case anyone is wondering i'll post the scale footprint of my trunk along with the height AudiTT trunk - Album on Imgur
Edit: I also have googled P3 vs Type R in a few variations and most results are not helpful and just say "mine are better"
Well I do like pretending to only care about SQ (the reason I went with a sealed box) when i went from a crappy DUAL BP1204 12" BANDPASS box to a nice sealed alpine type S I really liked the quality difference. However, I missed being able to make stuff vibrate or at least feel like my seat was vibrating. Then again I feel like volume should not be the biggest of issues for 3 decent 10s.
3 10s should get decently loud in a hatch, sealed or not. I think you are on the right track, doing 3 10s sealed... Would give you a good blend of output and SQ. Id personally go with the Type Rs, great subs for the money.
Those are the only ones I found people talking about. The P3 is $120 on Amazon and the type Rs are on eBay for 140 but I'd be up for using anything under $150 since spending $500 on subs may be a bit much for me.
So any suggestions on which 10 " subs I should be using?
PS I plan on replacing the planet audio stuff in the near future.
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
D0ZER
D0ZER
MN
snyderd758
    May 16, 2024
    May 16, 2024
