Sold 2x DD Z1 Amplifiers - $650 each / $1200 pair
sundownz
Pro Seller
Supporting Vendor
Shipped in continental USA.
NO TRADES - NO TRADES - NO TRADES
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
Rated 5000 RMS @ 1 ohm each.
correction the dd z1 isn't a big fan of .5 ohms. It will run for a short time but 9 times out of 10 they will blow a mosfet. 5000 out of 1 amp is alot. and this will draw 1000 amps at full tilt. thats a lot of current for most 14 volt systems. its a monster I tell you that much. with this amp i could only get about 5 seconds of burp before i drained 4 batts. but with 2 audiobahn immortal 15's at 1 ohm getting true 2500 watts with 0 sound deadner i was able to pull a 152.7 so and the box was tiny about 2.5 cubes at 35 htz off of a song by lil wyite (oxycotton)
i know someone who ran it at .35, runs a 200a alt and 2 walmart batts and drops to high/mid 13s?
I found them to be more efficent than the AB 500.1 or the Rockford t30001bd.One thing I would concern myself with is the serial number to see if it's an old model or a newer one.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
bobc04
