Except one is voltage dominate and one is current dominate.That’s my thought as well
I'm wired at 1.5 ohms on each amp myself ...lolMe too x 3
Sent from my SM-G950U using Tapatalk
LOOK UNDER MY NAME.. u believe that was my (60yr old) wife's idea after i told her about it?Mr2ohm imo is the best
I love it!!LOOK UNDER MY NAME.. u believe that was my (60yr old) wife's idea after i told her about it?
Probably will do 2 vp 700.1 wire to 1ohm per.On same power clamp, i gain .2 or .3 wired higher vs wired in the dirt.
This is like the 7K amp showdown where the JBL/Crown 6000W at 4 ohms metered a fair bit louder than 6000W at 1 ohm.On same power clamp, i gain .2 or .3 wired higher vs wired in the dirt.
Non sense. Loldoing a bit of ot reading but found a page that says wiring multiple vocal speakers in series vs parallel you loose low end response in series in exchange for a warmer mid section. while parallel keeps a flat tone with lower extension.
