Again, a battery or capacitor isn’t going to stop light dimming. The nominal alternator voltage should be around 14V (Typical voltage regulators are 14.2V +-.2V). Batteries voltages are around 12.8V without considering leakage or equivalent impedance. You can have a 3,000CCA battery installed, it’s not going to make any difference. Capacitors just don’t have the energy storage ability to stop large drops in VA.and second battery will only help solve the problem, you really cant solve light dimming with 1 thing.
the second battery will help you stabalize your voltage, but only to a point. it helps stabalize your voltage in that fact that you have more amperage at you disposal.
remove as the voltage goes down the current (amps) goes up, and when the volts goes up the current goes down.
a second battery is most useful when running the stereo with the car off, when the car is on it is running off alt power, if the car is running and the voltage dips below 12v, you are running off of battery, it is there to help pick up the slack fro the alt.
if your only consern is light dimming and dont really care jsut throw a small cap on the power wire of the headlight then, itll solve the headlight dimming, but you stil have a problem.
also people in competition (im talking heavy hitters) the only real reason they get a big alt is to charge all those batteries.
i mean thing about it lets say you are running multiple amps and the current draw from the amps is 500amps or more, whats more locical to do? add more batteries or get several alt that can put out over 500 amps? you would need about 3 alts for that atleast and thats assuming that each alt can put out almost 200 amps at idle, which i dont know any that can do that.
for the daily driver that has light dimming, get a better battery or a second battery and upgrade the alt and do the big 3, and your problem will be solved.
also if you are your voltage is dipping below 12v you are putting some serious stess on your amps power supply, youll end up getting leaking caps, blown transformers and other stuff.
its all simple physics dont complicate it you have X amount of current draw from your amps, you need to be able to supply it with that curent draw, safely
actually a couple of batteries wirred in parellel will actually lower the resistance (think amplifier power you lower the load (ohm) and the amp is able to push more power) this theoretical speaking
guys there is no cheap way to do it just do it rigth the first time. an alt and a bettery battery
and for everyones information think about this one.
regular car battery= good for surge's (like starting a car
a yellow/red top deep cycle battery= good for constant power drains(like a car stereo)
blue top= deep cycle/surge battery
so what in reallity is better for a 1 battery car? the blue top, yes a marine battery
over time using a yellow/red top battery as a main battery you will either shorten its life by quite a bit or you will "retrain" your deep cycle battery for a surge battery
just something to think about.
I don't see anything I asked for, all I see is a bunch of names....which don't mean X battery is better than Y battery....these people are getting paid to use specific brands.lets see Scott Owens, Kyle Witherspoon, Danny Britain, Steve Cook, Terry and Miranda Jackson, Jay Odom, Mark Holbrook, Scott Van Ripper, Team Walrus, Neil Barber, Eddie Dejesus and MANY MORE. any of those names ring a bell? here's a hint they don't use die hard.
None of the above.What would beneift me the most though? another battery or a bigger battery? And if I kept just 1 battery I would need to get a marine batterY?
I did the big 3 in 2 guage wire. And I have 4 guage wire running from my battery to my cap.None of the above.
If you have voltage drops, then increase your wire ga, and match your alternator to your load.
And I can’t imagine anyone driving around with an actual 500amp load, hell any daily driver would rarely have a load in excess of 150amps average, .
again huh? have you ever been to a comp? the only way i can see this is some local highschool thing, other then that they pull over 250 ampsand any non-pro competitor would rarely have an average of over 250amps during competition.
With those amps, you were probably loading the system with around 1/3 of those numbers on average with your system turned up to be really loud.huh? i ran 3 amps in my daily driver and was pulling over 350 amps for a good amount of time at a time.
had 2 PG x1200.1 (each 120 amps)
PG x200.4 anothe 120 amps.
and they will pull more when need be, plus add oll the other little processing gear.
all this off of the stock 85 amp alt, a redtop upfront and a kinetic HC1800 in the rear, voltage never hit below 12V.
LOL, fuses wouldn’t allow double the current for more than maybe a couple milliseconds.again huh? have you ever been to a comp? the only way i can see this is some local highschool thing, other then that they pull over 250 amps
remember how meca changed the class rattings? why because of cheater amps sayin 100 watts putting out 1000watts. but you really cant do too much with how much current they pull.
a fuse will hold DOUBLE its rated power for a short time (about 30sec-1min maybe more)
so in comps if someone has 150 amp fuse t'll hold 300 amps for a decient period of time.
the exile X5 alone pulls over 500amps, look at some other big amps some of the hifonics pull over 300, and what about the crown amps, talk about current hogs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
again 90% of the competitors use several batteries for a reason...it works plain and simple. they use there HO alts for charging purposes for all those batteries.
250 amps of current draw is not that much for what people are running now a days.
WRONG!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif they are kinetik customers or were.I don't see anything I asked for, all I see is a bunch of names....which don't mean X battery is better than Y battery....these people are getting paid to use specific brands.
The fact remains that a battery has a different potential than an alternator. Voltage drops don’t stop when you add another battery, you may lessen the extent of the drop BUT there is no reason to lessen the extent when you can eliminate it with an alternator which matches the load. This is regardless even @ 10x HC1800 batteries. Your statements of additional batteries stopping dimming are wrong; Anyone with any understanding of basic physics knows the same.WRONG!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif they are kinetik customers or were.also a high outpult alt only does 50-60% power at around idle. not the system i have now but the last two i had dipped with a bass mechanic cd @ or going under 30mph off of 160 amp and 180 amp alts. system potential draws were 130 A and 175A. my tempo out of the bunch was the only one i put a second battery in and all my dimming went away when i did(yes already had a high output alt but it didnt stop dimming at a stop light lol) my firebird i ended up cutting away some unneeded plastic and went up another size in a better than factory wet cell. besides that a good battery wont up and die in a few seconds or minutes of playing at high volume unless you are trying to drive a 10kw system off of it. in the era of large class d's and super subs its WAY too easy to surpass the output of a high output alt for it to stand alone. nearly all amp companies make a 2kw amp and higher. in that reguard if you had 1 of those plus a 400 watt mids and highs amp you would at least need a 240 amp alt and something to back that up (another battery: ). hell i even have a buddy in his daily driver with 2 4k mojos driving 2 15's on a stock alt. he has 3 2400's tucked behind his box +1 under the hood. hasnt had a problem yet in about a yr and a half.
if all batteries were close to the same they would all fart about the same #'s and have about the same reserve. wet cell batteries lag well behind typically and have leakage issues vs agm. there were some special ultra low esr batteries at this years finals (2milohm and under with price tags of $1000 or higher).
may not stop a voltage drop but definately controls how far it will drop. which stops the amps from blowing.The fact remains that a battery has a different potential than an alternator. Voltage drops don’t stop when you add another battery, you may lessen the extent of the drop BUT there is no reason to lessen the extent when you can eliminate it with an alternator which matches the load. This is regardless even @ 10x HC1800 batteries. Your statements of additional batteries stopping dimming are wrong; Anyone with any understanding of basic physics knows the same.90% of any driver on the road with an OEM system can match their alternator with the load, you’re an idiot if you drive around actually running your system @ 2,500 watts (I’m not talking about installing a 2,500watt RMS system, I’m talking about actually running 2,500 watts average or approx a 200amp load)…..I hope who ever does that gets a boat load of tickets. Those people are the reason the government is possibly going to be banning high powered amplifiers from being produced, and are ruining installing high powered systems in cars for competition.
Hell, someone ACTUALLY LOADING 1,000 watts while driving will very uncomfortable to sit in and will let people a block down the road audibly hear you.
In regards to batteries, you seem to be twisting my points. I never said low ESR batteries aren’t inherently better than higher ESR batteries, I said Kinetic batteries have no data surrounding their “low ESR” numbers….and I fail to see anything backing this up./ Batteries have an ESR range as they discharge, I would never spend 1000$ on batteries, and just because someone else does doesn’t mean it’s better in any physical way than a battery costing 200$. Unless you have some test data comparing X vs Y you have no argument besides people saying that people use them who are sponsored to use them and followers who look at someone competing using them and decide to follow suit. Leakage values and ESR values probably vary by a fraction of a percentage when comparing two well built batteries. And anyone knows that numbers vary every time someone is metered, battery types have relatively nothing to do with this.
http://www.cardomain.com/item/LITLSMAX100LOL, fuses wouldn’t allow double the current for more than maybe a couple milliseconds.
But that’s beyond the point, when someone gets to the level of competing on the pro level they do use multiple batteries, because no HO alternator can support their load. Occasionally I have seen some people do it CORRECTLY (actually need multiple batteries) who isn’t competing pro. Regardless of your perception of system load, the typical daily driver doesn’t need multiple batteries for my above mentioned reasons.
You’re not paying attention to your lights then, because people can see dimming with under a 2 volt drop for a fraction of a second. It makes sense with a 60watt bulb @ 14.4V dropping to 13V. Humans can very easily see an event around 20hz, and the 1.4V drop probably is a little over a 200 lumen difference. Very noticeable.may not stop a voltage drop but definately controls how far it will drop. which stops the amps from blowing.you have a big misconception of what a kinetik sponsorship is..they dont get paid and they dont get "free product".
just takes a basic understanding of pre physics (was taught to me somewhere within the first six weeks of basic circuit analysis full yr before we were required to take physics) to figure your question out. in systems i see dont get a noticeable dimming until it drops past 11.5-12.5v (same way as lights dont get "brighter" until you get past 14.5v or slightly higher as if had a voltage regulator go out and the higher the rpm went the higher the voltage got somewhere at about 16v i would say i thought my brights were on untill i slowed down lol..)
The only way an amp is going to get damaged, is if the VAin is greater than the amplifier is fused or CB is printed (ie. Including internal components) to handle. Possibly if the output is very clipped, the output stage may become damaged over a lot of use, but that’s not common. The amplifier isn’t going to get damaged from under powering it.you are also wrong in your statement about your numbers with the meter. if they vary greatly within the same system then you are sandbagging or something is broke or simply lost . i will also stand behind what i say/said about the numbers can and do vary between "brands". single cell wet lead acid vs higher tech batteries and high end battery vs high end battery can yeild more than 1 db and in groups over 3 db. in competition when you can get beat by .1 of a db it matters. i dont see where you have an argument as it is well known knowledge to competitors. most really serious competitors keep a log book and depending on the round they are in dial the system up to do as low of a score needed to win thus saving their equipment for a later tougher round. generally speaking they are either right on or within a .1 db (if its on the low side of that my money is on they will be hooking it up to a charger)
the problem i think you have with kinetik is how they recommend their cells as they do it differently than batteries hitting more on the automotive side. kinetik rates for day in day out stereo power for the simple reason people look at cca and cranking amps and think thats the only thing that matters when selecting another battery. sure a small 14 lb agm cell can do 600-900 amps but it doesnt mean it will last in a system that does 2000 watts.if your system depends on it solely as its back up power source eventually it will break down(melt down). kinetik also shows aH (c/20) on their cells as they feel for a cell used day in and out its an important factor which it is. sure kinetik does well in competition but when it first started it didnt lean that way it was brought out because people were putting 1000+ watt class d's in stock electrical system cars and people were blowing up amps due to not haveing enough power....... if i didnt go into enough detail i apoligize as i dont work there anymore my recollection of "exact specs" can be off if by nothing else memory / or product improvement since the time i left.
That's typical.http://www.cardomain.com/item/LITLSMAX100
rated at 200% duty for 5 seconds
and the definition of "typical daily driver" around here isn't how you're probably defining it //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
