Northwest Region 2nd Annual Good Vibrations DB Drag in Bozeman MT - July 18th
AK,CO,ID,MT,ND,OR,SD,WY,WA
lol i dont know anyone running that combo...who have you talked to and what kinda numbers you getting out of those 15"s? oh wait are you one of seths buddys?
Hahahaha! Putting pieces together! If you want to get your Tacoma body dropped, let me know. I have a buddy that runs a fab shop and does KILLER work. Decently priced, too.
I actually built the enclosure you have.
MEL! This cat scooped up all of Seth's equipment! The XXX he has is the one we took to Twin Falls! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif I personally blessed that sub, so it is guaranteed to be loud. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Be careful how you wire it, I'd definitely test it with a multimeter, hooked up to the amp, on a tone, just to make sure everything is wired properly. Quad coils are weird to me. When I dropped my XXX in my horn (exact same enclosure as yours, but I got mine Line-X'd) one of the terminals got hemmed up on the sub cut out. SOoooo I ended up throwing 3000 watts to the one coil. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
If I didn't live about 7 hours away from Bozeman and need a recone (again), I'd hit this show up.
Hell yea man, like i said we will be having these annually so just wait for next year //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
For sure. I'd love to roll up there and surprise the hell out of everyone with a single 15. We did it in Twin Falls. Blew almost everyone out of the water.
Haha yea, the only guy here that i know of with a single 15 is a Rockford T2. He hits like 146ish... Montana could definately use some more audiophiles lol
But 146 on which metering device and where was the device placed?
At the Twin Falls comp I ended up getting a 143.9 and running consistent 139.5 bassraces. Termlab and on the windshield. I need to improve on bassrace. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
not at all just everyone i've talked to from wy. is runnin that setup or has run that setup. and yes I also run the RD amps
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif im from wyoming and i run none of the above..
what are you runnin also rock springs is only 3hrs or so away from me. cammeron I think we might be going to MT. next year
For sure! It's like a 7 hour drive, but I think it would be a pretty cruise. We can get your rig louder. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Haha yea definately just haven't found its sweet spot yet //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if i had the monies and a new motor sure we got a couple days to come up with it why not:rolleyes:
Any ideas on getting it louders?
if you mean me it'll get louder with a second D9 tomarrow and 16volts down the road plus I still need to smooth out the inside of the enclosure . I just want to do 155 on music that's all. I don't think that is too much to ask is it:)
I meant for next year!!! Plenty of time to find a new Honda mill!
Yours, mine, or Mel's? As mel stated (below me) he'll be sending plenty of power to the HDC315's. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Me, I need to beef up electrical and get more power. My enclosure is more dedicated to SQ than high numbers. If I wanted a burp box, I'd have one and be doing a bit higher. I still need to do a bit of tuning. Next time I'm in Whyoming I'll see about getting my buddy's dad to help me tune my amp with his oscilloscope. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I don't know what you're currently running, otherwise I'd be willing to help! If it's the 6 W7's, I can already suggest a proper alternative.
Not too much AT ALL!!! Bassrace a 49.9 class easy? //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
jake21
Lifted > Lowered
jake21
Bozeman, MT
skavenger
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
