280amp alternator with dimming head lights
dgaf
Swollen Member
I have two SA15s running off a 2500 mojo.
A new optima yellow 34/78 battery and a dc power 280amp alt under the hood.
Big 3 done with 1/0 wire, solid ground.
Headlights dim. Not sure what the voltage drop is, I should probably check that out, would do it now, but it's raining.
Do I need a second battery in the back? XS\Kinetik?
I got big 3 done.
I even ran a 4 gauge wire from my battery negative to a ground block.
The ground block is then attached to a bolt that used to hold down the back seats seat-belt.
I had the ground attached to the area you can see that was sanded off, it was attached with self tappers, that was before I got the idea to use the bolt there.
I had an issue with my last install having a bad ground, so I went through all the precautions to make sure it wasn't an issue this time.
if its a 280 amp alt wouldnt you need 2 runs of 0awg to your bat? and i think a second bat would help
didn't think a second run from alt to battery was needed since it's only powering a 2500w amp.
anyone else recommend adding another 1/0 run from battery to alt?
dgaf
Swollen Member
dgaf
727, FL
grandam888
