26,000 watt lanzar amp
Looks to be the same amp as the cactus K12 based on the terminal layout and 2 channel design, dunno where they get the 26,000 rating from though. I'm guessing that's a MAX (aka, B.S.) rating.
it is, i had thought they fixed this on their website
A legit 12k? Are you serious? More like a legit 8k....and a SD8k can be had for that 1500.
If this amp is the same as the cactus 12k, which based off the images it is, then at MINIMUM i'd say it's good for 12k, if not more.
The opti series is very good stuff and usually conservatively rated.
Besides, i'd rather pay that much for an opti than for some banana and coffee bean filled amp that when it breaks takes a year to get fixed.
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif:rotflol://content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
Only a testament to their durability evl won't last that long id wait until the mojos gave up then go evl honestly and trust me unlike 99.5 of the...
36
6K
Prob over the Budget after building an enclosure(Struggle to find materials for the budget).. But Id like to Try a 21" sub to see if I liked it...
16
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
12voltz+-
12voltz+-
lorain OH
psychoacoustics
