Sold 2200+ watts $200 plus shipping
allout13
The amp is a fusion nv-am2500d. its rated conservatively at 1780 watts, but it has been benched doing 2200+ at 12.5 volts! The amp needs repaired. A thief tried to steal the amp and in doing so broke the power and ground connections loose. It could be a cheap fix if you had the tools and knowledge. Or db-r quoted a repair to run between $60-100 depending on how long it would take or if there need to be any reinforcement. The amp will work fine if force is applied to the connectors, but it probably is not safe.
here are the pics
I can take more pics if needed just let me know
bump for a real good guy!
What kinda amps did you get Chad?
thanks
2 hypnotic hyp1200.1ds modded to run at .5 ohm //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
got a pretty good deal on them
really? know of any tutorials or anything to show me how to fix it?
Go out, buy a desoldering tip, a soldering iron, and some solder... desolder all the connections for the things you need to resolder.... then re-seat it (take it out, and put it back in.) Make sure it's nice and firm in there, and all the pegs are sticking out. Then slob solder all over it. (But make sure the solder doesn't go over the copper ribbon lines.) Done.
I think the "pegs" are broken //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
allout13
allout13
Georgia
allout13
