The amp is a fusion nv-am2500d. its rated conservatively at 1780 watts, but it has been benched doing 2200+ at 12.5 volts! The amp needs repaired. A thief tried to steal the amp and in doing so broke the power and ground connections loose. It could be a cheap fix if you had the tools and knowledge. Or db-r quoted a repair to run between $60-100 depending on how long it would take or if there need to be any reinforcement. The amp will work fine if force is applied to the connectors, but it probably is not safe.
here are the pics
I can take more pics if needed just let me know
here are the pics
