21 or 2 15s?
splwj47
well im debating between going with 2 15 death penaltys or getting a 21 inch dp/warden. if i go with the 2 15s i will be getting another dc 2k to strap my current one, and the same if i go with a 21 warden. let me hear some of you guys opinions, what would you do? 2 15s and 1 21 is pretty close to the same cone area. will be getting a design done by ram for which ever one i go with and there will be lots of power. opinions?
Ain't gonna be much louder with 2 15's unless they are a lot more efficient. Surface area is pretty close. Actually might go to the 21 because it only has 1 surround.
The 21 will prolly need more volume than the 2 15's though. So make sure you have the space available. 21 should play lower louder as well. So....really in the end, it is up to your wallet and wants.
i got the space will probably give it 8.5 cubes after port and sub displacement, and do the hole shibang on the box kerfed port 45s double baffle ect. ect.
two 15's has more cone area, and you'll have more power
Where the fack did you learn your math........
Say each sub has a 1" surround....that gives a radius of the 15" sub at 6.5". Now PiR^2 = 132.732 square inches of surface area....2 subs equals 265.464 square inches.
Now for the 21" = radius of 9.5". PiR^2 = 283.529 square inches.
283.529
- 265.464
= 18.065 square inches in favor of the 21".
283.529
- 265.464
thats what i get for using my iphone as a scientific calculator. screwed me over on a chem test as well lmao
splwj47
splwj47
Great White North
splwj47
