2013 WRX SQ ish build
Here is my equipment that I either have or is on order going in a 2013 Blue Plasma Pearl Subaru WRX.
Front stage:
- HU: Pioneer AVH-4000NEX
- HU harness/adapter/AWSC-1 (ae64.com)
- JDM radio bezel
- Custom speaker mounting brackets (subaruaudio.net)
- Amp: Sundown SAX-150.4
- Components: Image Dynamics CTX65SC (100w rms)
- Mids: Sundown Neo Pro V2 6.5" (150w rms)
Sub stage:
- Amp: Sundown SCV-2000d
- Sub: Fi Q 12" loaded (1800w rms)
- Custom ported box flush with trunk (2.5 net cuft, 40sqin port, 31hz)
Electrical:
- DCPower 250a h/o alt
- Front battery: XSPower D3400
- Trunk battery XSPower XP950
- Big 3 (KnuKonceptz 1/0g)
- Knu 1/0g,
- Knu knf23 dist. blocks
- Knu Krystal RCA's
- Knu 16g speaker wire
- Knu 10g sub speaker wire
- Knu terminals, etc
Misc:
- Knu 100 mil deadening 65sqft (doors, and trunk)
- Shrink wrap, wire loom/flex
Equipment looks great! Tell me how the neo-pro's are, as I plan to get some soon
Thanks man! I did some research and bought within my budget but I think I landed on a good well rounded setup and most of all focused on clean power.
I will let you know how the Neo Pro's are just give me a bit to get it all installed currently my car is being fixed from a hit and run.
I chose the Neo Pro's because they are oriented toward delivering punchy mid bass in car doors specifically and will makeup for what most normal components especially when mounted in car doors lack.
I also forgot to add that I ordered a dcpower 250a alt //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Alright, sounds good!
Does anyone have any recommendation for applying the sound deadening? Will the 100mil be enough? Should I use mlv? I'd rather not.
Also do you apply to both the inner and outer door skins/panels? And so you cover up the holes or keep them open? And should 60sqft be enough for 4 doors and the trunk? Should I use filler in the trunk.
If your car is anything like my 2015 WRX, than it's a rattle machine. Focus on the rear deck the most. I did inner and outer door skins and also covered up any holes in the doors, I even threw some deadener/ensolite on the inner door panel itself.
Yeah they are rattle machines even with the pitiful stock speakers. I'll try and do my best like you did. What's the outcome like much more solid? Did t get rid of the rattling or does the plastic door panel cover rattle regardless?
Thanks!
Thanks!
The doors I was able to just about completely turn rattle free. I put silicone on the rear view mirror to get rid of that rattle. The rear deck I deadened just about as much as I think I can for now considering I'm running 2000wrms on 2 ported 10's tuned to 32hz.
lyons238
lyons238
Coventry, RI
Beerdrnkr
