2009 Subaru Legacy Build log
Looks good, the only thing I would've done differently is in the box. I would've routed a 1/8" groove on the back side of the front panel around the oval opening and sandwiched the carpet between the 2 panels. That would clean up the inner edge on the sub baffle. But again, looks great.
TONS and TONS of deadening pics. Also little tip to you all If you're installing deadener Get a roller! I tried putting it on and smoothing it out with my hand bad idea that stuff is sharp!
Looks like a trunk lid is in need
Nice crispy clean stripped trunk
Doing the side walls! probably the weakest or thinnest metal on the car
Getting the trunk lid done
working on the floor
Wrapped the spare well Decided not to do the part where the tire sits because the weight from the spare and amp rack should be way more than enough to keep that pannel from ressonating. IT also had a cote of liquid deadener from the factory.
A nice finished trunk
Putting it all back together
Time to do the back doors and also a little update as far as the substage goes. He wants to go even bigger and run 2 sa-10s off of a crescendo 2000.1 and get a pair of CDT 6.5 comps on a crescendo 1100.1
itsblown
why is there smoke?
itsblown
Toledo OH
121jiggawatts
michigan born
    May 14, 2026
michigan born
    May 14, 2026
