2009 silverado amp/sub install problem...
Absolute Dan
I recently installed a rockford fosgate 2-channel amp, and 10" sub in my truck. It is a 2009 chevy silverado crew cab, with factory bose 7-speaker system. I purchased a modulator to tap into t he speaker wires on the factory amp, to convert to rca's. After spending a ton of time on this install to research wires, check power, and make it as neat as possible, I fired it up and the sub sounds terrible. I'm 99% sure of the amp and sub being ok as they worked fine before this install. I double checked the sub's ohm's, a 4 ohm sub reading 3.6 ohms. I have a 8 gauge wire ran directly of a fused connection from the battery to the + of the amp, the ground directly to a frame bolt with no paint between, and the remote wire directly to the remote wire/power antenna wire from the factory system. The modulator wires come from the factory amp listed wires, and I have checked the polarity on both the input and output wires. The sub sounds like it is blown when plugged in, with a terrible distorted sound with the music. HELP PLEASE???
You are going to have to Bypass that fact amplifier.You are running both amp supply to that ch it sounds like to me.I had an issue with a 20o6 camaro with the same issue, and I ended up pulling the HU, and existing amp and put amps, and new HU,and utilized the stock speakers for a bit.It saved me a headache,and after 3 weeks of bs,everything sounded great, and I was quite pleased.Im not sure how to bypass the existing amp, as it is supplied poss by the HU.In that car it was, yet, someone on this forum should know the right LOC to use for adding external amps/power.I think the issues lyes within that HU, as I had.Though I could be wrong.
sounds like a problem with the loc install. is there adjustments on them? iirc, that is a center console sub located behind the cup-holders under the dash. it works well to just unplug that sub and use the wires to feed the loc. leaving the sub attached, or not at least using one coil (iirc, should be a dvc) for the loc alone will lead to feed-back, as the sub will act as a mic and pick up what the new subs play, or even door closing and feed it right back into the amp to be played again. if you tapped into signal wires, then the loc is not going to work quite right recieving a low signal, and at the same time stressing the source, which can create distortion in itself, which would in-turn likely result in damage to the source. now, you are calling it a "modulator"..... um, if you really did get a modulator, please post a link, or brand/model, as the only modulator that comes to mind, is an fm modulator, that used to be used all the time to send an rca signal into your fm antennae to play on the stereo vi radio station, and will likely do all kinds of wierd things, and again, likely damage to something....
Have an '08 Silverado with the same 7 speaker Bose system...bypassed everything, ripped out the OEM head unit and replaced with Alpine H/U, all new speakers, new speaker wire, subs under rear seat, 2 amps and Big 3 wiring...don't bother fucking with the OEM GM shit, not worth it. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
hmm, we seem to like the oem stuff for daily just fine, and keep the nice features as well.....
I would love to know what you mean by "nice features". //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif GM may name their audio stuff under Bose but it is el crapola. My install involves much nicer equipment and way better sound...and I was able to keep things like door chimes, OnStar and satellite radio. It's all good bro.
your pushing an amplified signal into a preamp input!! not good!!!!
um, a loc is designed to CONVERT a high level source to a low level LINE OUT. hence, the name "line out converter"(loc)
actually, delco and delphi are pretty nice, as far as oem equipment build goes, way better than clarion, etc. and about the "bose".....um, you are right about one thing- bose equipment by itself is crap....the whole lot of it. however, it's engineered quite a bit. i know i can get more/better features from aftermarket, but the stock gm stuff already sounds real good for allot, and less money and headache for many. i have piles of nice heads, but i'm happy with the way it is.... and it's easy enough to even integrate aftermarket stuff to the factory equipment. i've gone both ways many times, and both have ups, and downs, and "worth it" is up to the owner to decide.
x2..there is NO integration worth a fk! Car audio is either stand alone or GTFO !
That being said,I need to get working on my 2011,OEM radio is for ballscheese
....a nd just how much is every single owner going to invest to go full stand-alone, and keep the features vs the $12 option? not even worth it most of the time, especially when you can get about 4k worth of power for the same price, and still sound decent.
Absolute Dan
Absolute Dan
Topeka, KS
akheathen
