2009 Honda Civic Si Project by JML Audio of St. Louis
Pretty nice so far not a big fan of that head unit but oh well. Were did you end up running the power wire threw the fire wall? I like that honda logo pretty nice.
+1...
Also, any hidden clips/screws that might break to look for on the door panels?
On almost every honda I've dealt with, you just look in the little door cup (the one that you put your hand into to grab when opening or closing the door.
-There's usually a screw down in there hiding under a piece of plastic (that piece of plastic breaks EVERY ****ING TIME!!! You can't win, so go to the honda dealer and buy a couple lol).
-Then right behind the door-open pull lever, there's another little plastic ring that hides the screw, remove it (will probably break too //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif) and the door is now only held in by those plastic clips.
-Just start at one of the bottom corners of the door and start pulling, it'll all just pop right off.
-The top is held in on the window sill. Once the bottom plastic clips are broken free, the panel lifts up and off of the sill hook.
-Once you get the door off, just wiggle the door-open pull lever through the door panel and you should be able to set it aside.
Hope this helps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
JML Audio
JML Audio
St. Louis, MO
DNick454
