2008 Camry SE
FurbiesAndBeans
Corona, CA
I just started making the build for my dad's 08 Camry. All i've done is the wiring, but here is what i'll be putting in:
06S10L7
2.0 Cu Ft. @ 34 hz
Directed 1100D @ 2 ohms
KnuKonceptz 4 Gauge wiring
LOC (i'll only be adding subwoofer to stock system)
Here's some pictures of the wiring and one of the sub =)
Not bad , but please , please grommet that wire you have running through the metal on both sides of the piece. Those area's back there are sharp as ****. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
K thanks. im not 100% sure if im going to leave it there, the amp will be on top of the box so its easier that way.
He means the firewall....
No, the hole in the trunk. Don't want the same thing happening to his power wire that happened to your speaker wire. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The 2.25cf enclosure is the SPL/Deep bass enclosure.
For some reason Kicker no longer lists a street bass medium sized enclosure recommendations.
A 2004 10L7 the manual has-
1.75cf + port
2.75x11.25"x, port 17.75" long
I'm sure you dad will love the stock HU with stock speakers being overwhelmed by a sub! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
And do the 1.75 or 1.5 box, 2 is way too big learn about Q values then rethink your box design.
ok, i guess since everyone says 2 is too big, then i will go for a 1.75 cu ft box tuned to 34 hz. i havent made the box yet. I plan on getting the wood cut this weekend or sometime during the next week.
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
FurbiesAndBeans
FurbiesAndBeans
Corona, CA
FurbiesAndBeans
Brendon Jenness
    May 8, 2024
    May 8, 2024
