2005 Lincoln LS build!!! PICS
MEMPHISFLEX
This is my buddies car, 2005 Lincoln LS the rims are off do to it being winter, but he has 20" Lexani Fires!! But here is the some pics and a quick video of the car!!! The car is very loud, and sounds very good, batteries fit good in the spare tire hole!!! System was easy, the alpine brain is under the drivers seat so rca's were a breez to install, and since the battery is in the rear also, wireing up the amp, and other batteries, were also easy to install!!! I also installed the power inverter, to run the PS3!!!!
The camera wasnt taking pictures very good today, and this is not finished, the 4ch atomic still has to be installed and im building a amp rack, for the amps, and its gunna look really nice when its done!!! We just wanted to get the subs and atomic 3000.1 hooked up, and the amp is at .5 ohms, and is doing right around 4-4.2kw!!! Its very loud and clear, and does not rattle as much as i thought it would, but these LSs are pretty tight cars, so it shouldnt need to much to get the rattles the car does have to stop!!
Deffintley looks like some nice loud equipment, but x2 on the horrible pics and what I could see it looks like it could be put in there better. I know you said you were not finished, which still baffles me why people make threads when it is not finished unless it was a build log.
Its more of a build log than anything, and the ground jumper is just two runs of 4 gauge, other than that its all 1/0 gauge, i ran out of 1/0 gauge ring terminals, so i had to use 4 gauge for the time being!!!
MEMPHISFLEX
MEMPHISFLEX
Chicago,IL
MEMPHISFLEX
