2003 Silverado
thats an awesome setup... im starting to build my truck up.. how do those Alpine components sound? i was thinkin about gettin em but im not too sure..
I would recommend them. They sound great! Both mids and highs.
ive been lookin for this kind of install in my 04 z71...i like the box...its exactly what i was thinkin...glad you gave us the measurements...looks good..
No problem. I'm actually thinking about making a new one over my spring break (2 weeks). I think I can get a little bigger box in there and that will bring my tuning down a bit. I also may try a loading board under the sub instead of firing it to the floor. I'll post whatever I do.
Well here is the new one. It is 2.13 cu. ft. tuned a little under 36 hz. It is definitely better on the low end. The box is actually 9" high front and back, the seat just makes it look angled. Its a tight fit for the seat to go down, but it does. With this bigger box, it seems like its moving a lot more air. I am going to try to get a vid sometime soon, but I don't want to play it around here. On to the pics...
It might look like the 4" aero is blocked here, but it is probably 1.5-2" away from the board you can see at the end of it.
Needed more port area.
4" = 12.56
3" = 7.065
= 19.625
5" = 19.625
Which is around 10 in^2 of port area.
So tuning is figured with 1 5" at 17" long. Might not be dead accurate, but its close enough. Two 4's was too much and two 3's wasn't enough.
ado
Go Boilers!
ado
Montpelier, IN
91Chevy
