2002 toyota tundra
I drive an '01 The only hard part is the trim for the inside door handle. I cracked mine because i've had them on/off more times than i can remember. I think the trick is to pry on the side nearest the rear of the truck between the lock indicator and the trim, then the same spot, but on the bottom. The side near the door hinges has a hook on it. It's been a while, but i think that's right
The panel goes on very well. I have zero vibrations.
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
4runnercrazy
