2001 porsche 911 SQ Audio Build - Mosconi, Ground Zero and Alpine
customaudioman
This is a build log for a 2001 911 turbo. Goal for this build is great level of sound quality with great output. The other important aspect I try to do on builds is making everything look like its factory. Staying within the OEM design and complementing it. But still have a show appearance when removing a panel or two. Here is the List of equipment
that will be used in the install.
Headunit - Alpine X008U 8" Navigation unit
Amplifers - Mosconi Gladen One 240.2
- Mosconi Gladen One 120.4 ( 2 of them)
Processor- Mosconi 6to8 DSP with mini controller
Components - Ground Zero Plutonium 6.5" midbass
- Ground Zero Plutonium 3" mid range
- Ground Zero Plutonium 1.1" tweeters
Subwoofer - Ground Zero Hydrogen 12" subwoofer
Backup camera- Rydeen Mobile HD mini camera
Bare carful with the inner sub frame on the door if you decide to take them off! Was working on a customers 996 replacing a door release cable and when I took it off it just slipped and hit the paint in the jam. Sliced right through the towel I had set there
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
You should use an adapter. You might gain some insight on a Town Car forum as well. https://www.installer.com/cars/by_car.php?carid=3402
If the company made the adapter for your specific model, they would have taken into account the OEM amplifier and put in a sort of line output...
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
customaudioman
customaudioman
everywhere
quakerroatmeal
    Jun 3, 2024
