2 type r 1242d sub wiring
so what i said is right but not the picture?
the picture isnt mine i just wanted to give a visual to show everyone what im talkin about
in the picture the + and - are hooked together, its supposed to be both +'s hooked together and both -'s hooked together, if u want a 1 ohm load
i believe in that picture they are wired in a 4 ohm load
yea,,, no need for plugs,,, just start from one sub,,, dual voice coil, start at one voice coil, postive to other postive on that voice coil,, same as negative... 1 sub done,,, now run the postive from the first sub over to the first postive on the 2 sub, then run the postive to the 2 voice coil. same as negative again, then on the last voice coil, run wires to your selected source
^BBQ^
^BBQ^
milton, FL
grillman6000
