2 type r 12'' (what will push these subs)
I don't know much about amps but i have 2 12'' type r woofers and trying to find a amp that won't cost to much to push them. any suggestions?
I have a ALPINE MRV-F409 4-CHANNEL AMP i don't know if it will push it enough but is it good? its a special edition amp also.
Thank you
800-1000 watt mono amp....
im guessing you have dual 4 ohm subs so a amp thats 1 ohm stable
if dual 2 ohm you need 2 oahm stable like kicker
that amps only good for highs/mids
800-1000 watt mono amp....im guessing you have dual 4 ohm subs so a amp thats 1 ohm stable
More like 1200watts plus at 1 or 2 ohms depending on VC configuration of the subs.
Correct, do not use that 4 channel on your subs,
Is kicker the only brand that has 2 ohm stable amps? Why can't he get a 1 ohm stable amp that does the desired power at 2 ohms if he comes across one?
OP, what's your budget?
CADENCE ULTRASHOCK A7+HC 1200 WATTS@1 OHM - eBay (item 120648959314 end time Nov-24-10 17:04:16 PST)
wont get a better deal and amp then this, things are monsters known to put out 1400rms plus, codesigned by zed audio in 99 and 01, this is the 01 model due to the silver clips and are the more powerfull ones
needs a nic epwder coat though lol, super effecient, wont kill your electrical at all, was hand built in america
Cadence 1 ohm mono amplifier zrs8 - eBay (item 290501319285 end time Nov-23-10 20:07:09 PST)
another amazing deal
Audiopipe AP15001D Class D Amplifier - Ships Same Day!! - eBay (item 270655037453 end time Nov-25-10 12:01:03 PST)
if you want new this is the best way to go
If they are the 500w D2 version then the Kenwood KAC-9105d would work great!
It puts out 900w @ 2ohms, so series/parallel wire them down to 2ohms and you'll be set.
I have had this amp since the summer pushing my KFC-3012s and it works GREAT at 2 ohms
Edit:
I think you can get one for around 200 now
jarvo2807
jarvo2807
Joshua Tree, CA
Bassin Buick
