2 subs, 1 amp
what model subs and amp you got... or better yet give me the specs for both (ohms, watts,# of vc's) and i'll tell you how to wire them up.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
dallas101346
dallas101346
va
imral3
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
