They will easily play 5hz below tuning in your enclosure, so if 35Hz is your low point then 40Hz tuning would be fine.how well would they play tuning them to 40hz tho, 37 is high to most people, but 40 would almost seem to high and not play very low. again tho i dont listen to alot low stuff, 35hz would probably be my lowest. If i can atleast play decently there then i might consider it
SQ subs will normally play 6-8Hz below tuning with no issues. If box is huge/port area is giant/way over RMS on power then you "might" run into some problems...
