2 SA-12s or 1 AQ HDC4?
Sound different how? I run an HDC4 18 daily and play pretty much everything but rap and it sounds very good. Puts up decent numbers also for a trunk set up...
idk... I just feel like it get's sloppy at 15+ .... but I dont really know that as a fact. Just hard for me to wrap my head around how it doesnt get sloppy/slower.
I understand that it has to do with box size mainly... it's just... hard to think how a larger woofer can play at the same accuracy as a smaller one.
Larger subs have a higher mms, which is why people think they play more "sloppy". However, mms has very little to no effect on how "sloppy" a sub sounds.
If the motor strength is there to control the sub and box is built right you would never know the difference.
I think that rumor started cuz people were using junk subs and putting them in way too small enclosures so they were peaky and sounded like *** on music...
Could you do a simple explanation of what mms is and what it means to me?
That's good to know. Thanks
If space isnt an issue get the 2 sa's
I have the whole back of a station wagon to use up. Shouldnt be a problem.
Not even a question. 2 sa 12's done right will kill 1 hdc4. If you have the space get the sa's.
Will the 2 SAs get lower than the 1 hdc4?
I agree with getting the 2 12's. Good luck getting warranty service from audioque.
Warranty is something I had not thought about. Thanks for bringing that up.
mms is the moving mass. It really doesn't mean much by itself. It is just one parameter. It is just the main reason the rumor started about larger subs being sloppy, because there is more mass to move and they can't possibly respond as fast. The entire myth is untrue.
oops
ah. Thanks.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
731
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
982
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
860
sjv13
StayStrange
sjv13
Lansing, MI
rebelfromva
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
