2 questions...one thread. Formula for Air space in fiberglass enclosures and....
1) area is always lxwxh or whatever for squares and triangles so if u need to break the box into sections and then calculate separate areas then combine for the total value do that.
2) u can change tuning by adding chambers to the slot port or extending it
I would fill trash bags with known volumes of packing peanuts, etc. See how many of the known value will fit into the box.
If everything else remains constant, which will not be the case unless you have external ports:
Longer Port = Lower Tuning
Less Port Area = Lower Tuning
Less Net Volume = Lower Tuning
Thats pretty much what I used to do when I worked at the shop. I took cardboard box with a known internal airspace and filled it with packing peanuts. Then I filled in the box. But I didnt know if there was some formula anybody used since I dont have the packing peanuts readily available anymore...I could just get some from them I guess.
If I slotport that 13W6v2 what should it be tuned at for SQ? 30hz? JL's recommended slot ported box is tuned at 34.5hz. And I dont want to just make that box. I want a custom box Im kinda stuck. Anyone hear a 13W6v2 in a SQ slot ported box? How do I figure the box volume, port area and port length for that sub at 30hz?
I like playground sand better than packing peanuts. It gives more accurate numbers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i use a bean bag chair. they usually have the super small round styrofoam pellets which work better than peanuts, not as fine as sand but much easier to remove. when you are done measuring you just pour them back into the chair and wait til the next use or sew it back up and return it to the store.
Sideways17
Sideways17
Franklin Grove, IL
nineball
