2 or 4 speakers
clubcar13
Hey guys,
i have a 4 door f150 and I have cadence components in the 2 front doors that sound amazing and are super clear and loud. Right now I do not have any speakers in the rear doors. Should i put some 6x8s in there becasue that is what the opening is for or should I just leave them empty?
thanks,
Mike
If it sounds fine to you now I would not add them. Everyone will suggest having a good front stage and forget the rear speakers. I would only add them if there are people riding back there a lot.
if it is mainly you in the truck, forget them, but if you have company that sits in the back then you may wiant to consider it. but for you in the front, the rears are just goint to make things more complicated
i used rear fill for years.. and when i moved to just front speakers... didnt like it as much
after tuning and working on my staging more... and using that for around a year.. i put in rear fill speakers just to see if i missed it.. and ended up removing them right away...
you dont need em.. at first it might sound different... just cause you're not used to it..
clubcar13
clubcar13
Boca Raton, FL
Etac
Mike Mccabe
