2 or 4 gauge power wire for two amps
grunt66
Need some help here. I am installing the following amps in my vehicle.
Zapco Reference 500.1 (1 X 360 watts at 4 ohms , Max current 40 amps)
DLS Ultimate A4 (4 X 85 watts at 4 ohms, Max current 95 amps)
I was told by a local installer that a 4 gauge power wire would be fine. Then I looked in the Zapco manual that came with the amp I saw the chart for running a power wire for different current demands. The total max current for both amps is 135 amps. The Zapco manual states that between 125 -150 amps for a 10 -13 foot power run the size of the power cable should be 2 gauge. If the run for the cable is 13-16 feet then the power cable size should be 0 gauge. The DLS manual states for the A4 by itself at a power run of 4 meters (13 feet) the power cable should be 4 gauge.
All speakers will be running at 4 ohms. The DLS will be using two at 4 ohms to power the front speakers and two channels at 4 ohms to power the rear speakers.
This is going to be my first install and appreciate any and all advise. Hopefully I provided enough information. It appears that I need to run at a minimum a 2 gauge wire. Also for the in line fuse at the battery for the power wire the DLS manual states for a 2 guage wire the max fuse should be 150 amps and for a 4 gauge power wire the max fuse should be 100 amps. Does this sound correct.
Thanks in advance.
4 x 85 = 95 amps? That doesn't sound right.
Double check that figure for the 4 channel.
135 is right on the edge for 4 gauge.
If it's true, then you should probably go ahead and upgrade to 2 or 0 gauge. There's no point in choking your nice/expensive amps because you wanted to save $30 on cable.
ETA: My 4 channel is 4 x 110 watts @ 4 ohms = 40 amps; (4 x 220 @ 2 ohm) = 80 amps
Assuming you are running the 4ch amp at 4 ohm per channel, 4 gauge should be fine with a 100amp fuse, as it won't pull anywhere near the full rated current draw. If you intend to upgrade anytime in the future, I would go with bigger wires.
grunt66
grunt66
Vista, CA
dipitydoo
