Good 5/3 Channel amps?
Was thinking about ditching my two amp setup to clean up my trunk.
are there any amps that do around 600rms for the sub channel and 100-200rms either bridged or between the two channels
I purchase the new digital Alpine pdx amp series. You will probably have to purchase two pdxs and stack them one on top of the other. It about size of a 12" diagonal notebook computer the size of the Pdx.
Take a look! It nice!
I plan on running a DLS Ultimate A5 for my next setup which may work for what you want. It's 85x2@4 ohms plus up to 780x1@1 ohm for the sub(s). If you needed more power for the components they also have the A7 5-channel giving 200x2@4 ohms bridged and up to 600x1@1 ohm.
my PPI PCX 4125 would be perfect for that...Its a 4 ch....any larger powered quality 4 ch 125 x 4 or above should give you what your looking for also....by bridgeing the rear ch's....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The certificate that came with my zx550.3 showed a total output of well over 700 watts. If I remember correctly it was 743. A friend of mine has the amp now so I don't have the paper on me. I used to have a pair of the kx550.3's and they were actually right around the same, if not less total output.
alex5857
alex5857
California
2500hd06
