2 ohms to 1 ohm reset gains??
not the - and + that are right next to each other. the - on the left is hooked to the + on the right and the - on the right is hooked to the + on the left. the the negative on the right is going to the amp and the + on the left is going to the amp.
it shouldn't be like that.. it should be a + from one coil to the negative on the other coil and then the negative from the first coil to the amp - and the positive from the 2nd coil to the positive on the amp. the way you have it I am surprised it hasn't done anything wrong yet or made it play funny
idk i had a pre made box/ amp/ sub before this. and this sub sounds fine to me but thats all relative i guess. so it should be + to + and - to - then run a + and a - to my amp for 1 ohm. correct?
yes.. all the + go together and then a run to the amps +... all the - together then a run to the amp.. for 1 ohm
kk sweet. i feel like my car will blow up when i do that tho lol. cuz I'm doing 300w right now and have voltage drop.... lol like down to mid 11's if I'm not watching... yeah def getting a h/o alt. and i metered a 128.9 on 300w. **** //content.invisioncic.com/y282845/emoticons/santa.gif.e1ec9cf2e0a0dd232ad35aa594a126d0.gif
if you are dropping to 11s there is a MAJOR ISSUE on 300 watts.. try fixing the wiring and keep it at ACTUAL 4 ohms not what you have now and tell me what happens then..
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
