2 Ohm?
i don't know of any 2 ohm speakers, but then again, my knowledge of speakers is decreasing as i haven't been keeping up with it:(
ok....no i understand what your saying......couldnt quite figure out why u wanted 2 ohms...do u have any comps right now?? if so then u might check evay for a us acoustics amp.....they usually go for about 75 or so for that wattage ....never know...peace
Originally posted by Goddyd4me ok....no i understand what your saying......couldnt quite figure out why u wanted 2 ohms...do u have any comps right now?? if so then u might check evay for a us acoustics amp.....they usually go for about 75 or so for that wattage ....never know...peace
I have the amp just need some speakers for the amp
It also lowers the amps efficiency and raises the current draw.
461
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
298
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
993
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
MMATS COMP
4 15s didn't see no wires
MMATS COMP
Grand Rapids, Michigan
joshpoints
    May 16, 2024
    May 16, 2024
