jellyfish420
i design boxes .......
so when designing a box you would use the t/s parameters for a single coil, insead of either the series/parallel parameters?
Yes. On a DVC sub, the published T/S specs are commonly measured with the coils in series. But, if you are only using one coil, then those published T/S specs will be worthless, so you would need to remeasure the t/s params with only one coil being used. And you need special equipment to be able to do this....not something most amatuers possess.so when designing a box you would use the t/s parameters for a single coil, insead of either the series/parallel parameters?
i was just asking someone on here, i think steve, gave me the t/s param on my sub for single coil, parallel, and series.
I wouldnt even tell people they can do that overall its a huge no no. Also with amps and SQ ive personally always found class a/b amps to be the best sounding especially when some of these new power amps ie JBL 1200.1 hifonics bx1500 and so on have an absurd THD.No, it won't ruin the sub. But it will completely change the subs parameters, which means the recommended box size won't work and you would need to re-measure the subs T/S parameters, the motor strength is reduced, power handling is decreased, etc etc etc. So, while it won't ruin the sub, it's not a good idea for the average joe to try it.
wrong, this is fact. just look at the specs of any amp and you'll see THD up immediatelyThat may be your personal preference, but not a fact.
You said mono amps have better sound quality than 2-channel amps before you mentioned anything about bridging. Prove it. But regardless, bridged or not, prove that a mono amp sounds better than a 2-channel.wrong, this is fact. just look at the specs of any amp and you'll see THD up immediately
i believe your wrong.....more resistance in a hose structure = more pressure. a bigger hose puts out the same amount of water because it is the same pressure being released from wherever the water is sourced but the hose does not carry that pressure. (smaller hoses shoot water farther than larger ones unless pressure is raised to make the larger hose work harder to shoot the distance the smaller one does. there was a big thing on this i believe. now as far amps.....i believe its kinda the same....at the lower impedence it shoots out more current......sorta like the smaller diameter water hose. so if u comepare an amp to a hose the smaller dimater hose only compares to the diameter of the hose and how far it shoots......not the pressure being made, but the pressure being HELD.The resistance (ohms) and the power is based in simple electrical engineering theory.
(think of going from a regular garden hose to one twice as big). Your amp puts out twice the power, provided it can handle it (and the electrical system of the car and install in general).
