2 ohm vs 4 ohm
i am running 2 ohm, i checked before i wired it
Brad, I copied this from the webpage for your woofer from the link that YOU put in your original post....
"Dual 2-ohm voice coils allow you to wire this sub for 1- or 4-ohm impedance, giving you more flexibility in setting up your system. Rockford Fosgate optimizes this Prime sub for both sealed and ported enclosures so you can choose the type of bass you want in your ride."
You cannot wire a DVC x 2ohm sub to 2 ohms. Only 1 ohm or 4 ohms (as stated in YOUR link).
With the amp you have you have to wire the coils in series for a 4 ohm load.
Brad, I copied this from the webpage for your woofer from the link that YOU put in your original post...."Dual 2-ohm voice coils allow you to wire this sub for 1- or 4-ohm impedance, giving you more flexibility in setting up your system. Rockford Fosgate optimizes this Prime sub for both sealed and ported enclosures so you can choose the type of bass you want in your ride."
OP already said he was only using 1 coil, that'd leave him at 2 ohms. (However, this technique can be dangerous to your subwoofer)
Thank u all for all the info to help me out how to wire it. the sub was only 23.00 so I was not to worried about it messing up but now u can fix it and hopefully get better sound
again thank you guys for helping me out with this, it does make a big difference, i wired it correctly and set the gains properly and it sounds great guys. thank you
bradl79
bradl79
NLR
Side Show
